CVE-2021-40095 - Reading arbitrary files
CVE:CVE-2021-40095
An issue was discovered in SquaredUp DS for SCOM 5.2.1.6654. The Download Log feature in System / Maintenance was susceptible to a local file inclusion vulnerability, leading to the ability to read arbitrary files on the server filesystems.
What should you do?
If you are using a SquaredUp DS version earlier than 5.3.1, update to version 5.3.1 or later.
| Product | Affected versions | Resolved versions |
| SquaredUp DS for SCOM | Versions earlier than 5.3.1 | 5.3.1 and later versions |
| SquaredUp DS for Azure | Versions earlier than 5.3.1 | 5.3.1 and later versions |
| SquaredUp DS Standalone | Versions earlier than 5.3.1 | 5.3.1 and later versions |
Acknowledgement
If you believe you've found a different security vulnerability in one of our products please report it by emailing our support team so we can work on fixing it: [email protected]
| 10.11.2021 | Initial release |
