How to create a dashboard
This article covers:
- View mode buttons
For detailed information about dashboard layout, adding columns, rows, and split tiles see How to use the dashboard designer.
SquaredUp DS Standalone > Dashboarding > Tiles
The dashboard is saved as you go along so there's no need to save your changes. You can find your dashboard by clicking on the right-hand menu ☰ > system > unpublished. Draft dashboards are not visible to anyone other than you.
Creating a new dashboard
In SquaredUp DS navigate to where you'd like the dashboard to be created. Hover over the + button and click dashboard.
Edit tile - Configure tile
The most important part of any dashboard is the data. The edit tile (cog) button and configure tile links both allow you to choose the kind of tile you want to add and then configure it.
Publishing your dashboard
Who can view the dashboard?
On the main menu your dashboard will be visible to everyone.
If it is within a Team Folder
If the dashboard has Open Access enabled, or is added to the Open Access navigation bar, then it will be visible to anyone, even unlicensed users (see Sharing Dashboards with anyone - Open Access).
Edit mode buttons
Discard a draft
If a dashboard is not published yet (draft), the discard and discard changes buttons will delete it.
If the dashboard has been published, and then you make changes, discard will discard the changes and leave the previously published dashboard live.
If you unpublish a dashboard and then discard changes then the dashboard will be deleted. Admin users can restore deleted dashboards from the Recycle Bin
Unpublish
Once your dashboard is published you will see an unpublish option if you click on the cog to edit the dashboard.
Unpublishing the dashboard removes it from view. You are asked to confirm this, as the dashboard will return to only you being able to view it.
If you discard a dashboard after unpublishing it then the dashboard will be deleted, see Recycle Bin
Move
This allows you to move the dashboard to a new location on the navigation bar (How to edit the Navigation Bar).
Delete a published dashboard
The Delete button allows you to delete a perspective quickly.
You can navigate to a dashboard, click the edit button and then click the delete button.
Other options to delete a dashboard are:
You can delete the dashboard from the navigation bar. Deleting it from the navigation bar will delete it completely, not just from the navigation bar.
Information about editing the navigation bar
The global navigation editor is accessible only by
SquaredUp DS administrators (How to make a user a SquaredUp DS administrator) from the right-hand menu ☰ > edit navigation or system > dashboards.This allows
SquaredUp DS administrators to reposition globally viewable folders and Team Folders on the navigation bar, as well as the ability to move any globally viewable dashboards.Globally viewable (normal) dashboards are shown simply by the dashboard name.
The edit team folder icon is shown next to Team Folders and clicking it will take you to the Team Folder settings page where you can view and sort the dashboards within the Team Folder. The view folder button takes you to the folder itself to view or edit that folder. The delete button will delete items. This deletes the dashboard or folder and sub-contents completely, not just from the navigation bar. (Admin users can restore deleted dashboards from the Recycle Bin) If the dashboard is in a folder, you can go to the folder settings
, click the edit
button, and delete it from the folder. Deleting it from the folder will delete the dashboard, not just from the folder. Admin users can restore dashboards, see Recycle Bin
Clone
This creates a copy of the dashboard in the same location, ready for you to edit.
Edit actions
This allows you to add a button at the top of a dashboard.
For more information see Action buttons for dashboards.
Edit JSON
This allows you to see and edit the JSON behind the dashboard, which can be useful for troubleshooting with the help of SquaredUp Support
Click on the
edit dashboard button
Click on the
edit JSON button.
You see the dashboard's JSON.
Dashboard Settings
Dashboard settings apply to the whole dashboard and override any global defaults.
Graph colors
Graph colors are set to match by label by default, meaning that the same color will apply to an object with the same label across several graphs. See How to enable graph color matching.
Dashboard timeframe
Within SquaredUp DS, it decides which timeframe a dashboard uses when a user goes to the dashboard. Tiles set to use the page timeframe (not a fixed, specific timeframe) will use the default page timeframe every time the dashboard or perspective is opened. Users can change the page timeframe temporarily while they are on the dashboard, but their setting will only last until they leave the page. Their setting will only affect their view of the dashboard, not other users' views.
On Open Access dashboards, tiles that use the page timeframe according to their settings always use the default page timeframe.
You can change the default page timeframe for individual dashboards, or globally:
Changing the default page timeframe of a dashboard will affect this individual dashboard and it's Open Access representation.
The global default page timeframe is "last 12 hours". Changing this default setting will affect all dashboards (including Open Access dashboards) that don't have an individual default page timeframe setting.
Note: If you are sharing the dashboard via Open Access, these changes will also affect the Open Access dashboard.
Go to the dashboard you want to change the individual default page timeframe for.
On the dashboard, click the edit button
Click the settings button.
Choose the new default timeframe under Dashboard timeframe.
The dashboard will now by default use the page timeframe you chose. Users can still temporarily change the page timeframe while looking at the dashboard.
Tip: If you want to undo the individual page timeframe setting to let the dashboard use the global default timeframe again, you need to switch to the JSON view of the dashboard and delete the parameter that defines the dashboard's page
timeframe
(for example "timeframe": "last7days
Dashboard refresh
By default dashboards (and their Open Access versions) refresh every 60 seconds.
This setting allows you to change the refresh interval on a per dashboard basis, both for the normal dashboard and its Open Access version.
This setting overrides the global dashboard refresh interval.
For example, you may need to reduce the load on your external data, or for an API that has an access cost.
You can increase the refresh interval in increments, up to 6 hours. You can also decrease the interval down to 30 seconds on any given dashboard if you need to see the data refreshed more often.
To change the default refresh interval for Open Access dashboards you should change the global setting, see Sharing Dashboards with anyone - Open Access - Refresh Interval Setting.
View mode buttons
When you are not in Edit mode you will see the following buttons at the top-right of the dashboard:
Page timeframe
If you're looking for general information about what kind of timeframes can affect a tile please read Timeframes for tiles.
The page timeframe is the timeframe setting a dashboard is currently using. These timeframes are all relative to the current time, for example 7 days ago until now. When a user changes the page timeframe, all tiles that have use page timeframe set will adapt to the new timeframe. (Tiles that do not have use page timeframe set (i.e. are set to specific timeframe or custom timeframe) are not affected and won't change.)
The custom option can be used to set timeframes using ISO 8601 format
Default page timeframe
timeframe
Note: This setting affects all dashboards (including Open Access dashboards).
notepad
, and then right-click and select Run as administrator).In your SquaredUp DS folder, go to
\User\Configuration
and find theextensionpacks.json
file.Where to find the SquaredUp folder
Name of the SquaredUp folder
SquaredUp
for v6 and above.For v5
it isSquaredUpv5
If you deployed SquaredUp DS via the Azure or AWS Marketplace :The default location for the SquaredUp folder is
F:\
.SquaredUpv[Version Number]
For v5 it isF:\SquaredUpv5
.If you installed SquaredUp DS using the installer:
C:\inetpub\wwwroot\SquaredUp
For v5 it is
C:\inetpub\wwwroot\SquaredUpv5
.Open the
extensionpacks.json
file and add the propertydefault-timeframe
with the value for your new default page timeframe for all your dashboards and perspectives.Example for a default timeframe of 24 hours:
Copy{
}Possible values for the
default-timeframe
property:last1hour
,last12hours
,last24hours
,last7days
,last30days
,last3months
,last6months
,last12months
Save the json file.
Recycle the SquaredUp DS application pool.
Export dashboard to Excel
SquaredUp DS allows you to export the data shown on a dashboard to an Excel spreadsheet, using the Export to Excel button shown at the top right of the screen:
Each tile is exported to a separate tab within the file which is saved to the user's downloads folder.
Set Home Dashboard
The Set Home Dashboard button at the top of each dashboard allows you to set that dashboard as your personal home dashboard. A panel opens which allows you to Set Home, if no homepage is set, Clear Home if this dashboard is already set as the homepage, or Replace Home if another dashboard is already set as the homepage. The home dashboard will then be shown first when you log in or click the SquaredUp logo. This replaces the default home dashboard, which is the first dashboard on the navigation bar.
If a personal home dashboard is already set, you will have the option to replace it.
In System > Personalization you can see which dashboard is set as your personal home dashboard. Clicking Clear Home will revert you to using the default home dashboard.
Add Favorite / Remove Favorite
The Add Favorite or Delete Favorite button will add this dashboard to your favorites folder.
A Favorites menu will them be shown on the navigation bar, next to the SquaredUp logo.
In System > Personalization you can sort and remove favorites from the Favorite Dashboards menu, (no folder structure is supported).
Share this dashboard
