How to use Custom Labels
Custom labeling allows you to specify exactly how you want resources to be displayed, using both static text and dynamic properties.
Supported tiles
The following tiles support custom labels for Grid, Status Icon and Status Blocks tiles:
- SQL
- Web API
- Azure Log Analytics
- App Insights
You can configure a custom label by configuring the label panel when creating or editing a supported tile.
Mustache Parameters
Custom labels can use Mustache parameters (mustache syntax) to insert properties. If you're familiar with mustache, you can specify advanced labels that can transform properties prior to displaying them (such as showing only a portion of text, converting a number or reformatting a date).
A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, {{timeframe.start}}
will insert the start time, or {{name}}
will insert the name of the object(s) in scope.
For example you can use the javascript split method to separate properties into substrings to make the result more readable.
You can edit the creation date:
{{properties.creationDate}}
To become:
{{properties.creationDate.split('T')[0]}}
This removes the timestamp just leaving the date the resource was created as the sublabel:
The mustache helper
When specifying a mustache for a custom label, clicking the {{}} button or typing {{
brings up a helpful picker which shows all the properties of your selected resources, along with sample values.
Once the mustache helper is displayed, the list of properties will automatically filter based on what you type, allowing you to quickly find a property using a partial name or likely term. Clicking an item in the list will automatically insert that property into your label and complete the mustache.
Property names are case-sensitive and should be written as they appear in the mustache helperavailabilityStatus.location
not AvailabilityStatus.location
Note about using properties with hyphens from external APIs (for Web API, Elasticsearch, and Splunk tile)
Property names that contain hyphens (for example properties.name-with-hyphens
) can't be processed due to a JavaScript limitation. If you want to use a property that contains a hyphen, you have two options:
Original property name:
New format:
You can use timeago
to convert Unix timestamps from milliseconds to show a readable date and time. You can either display an absolute time (for example, August 20th 2021) or a relative time (for example, 20 hours ago).
The parameters for the value you want to convert can either be true
or false
Show Absolute |
Show Time |
Without Suffix |
With Prefix |
Tip: The default setting for all parameters is false
. If you only want to change the first parameters, you can just use timeago(value, true, true)
and it will be interpreted as timeago(value, true, true, false, false)
Examples:
{{timeago(value)}}
To display the absolute time as the date without the time:
{{timeago(value, true)}}
To display the absolute time as the date with the time:
To display the time with the prefix "for" for relative time and "since" for absolute time (for example, "the status has been unhealthy for 10 hours")
Option A) Use the fourth parameter and set it to true
. This will insert the appropriate prefix for the absolute or relative time:
timeago(value, false, false, true, true)
Option B) You can leave out the fourth parameter that controls if the prefix "for" or "since" is inserted automatically. Since you left it out, it defaults to false, causing no prefix to be shown. Instead you insert the word "for" or "since" manually before the timeago function.
for timeago(value, false, false, true)
To convert a time value from seconds to milliseconds:
{{timeago(value*1000)}}
Example with a Pingdom property:
Walkthrough: Displaying a custom label and sub-label
You may wish to specify your own label and/or sublabel.
Create a Web API Status Icons or Status Blocks tile.
Click on the label panel.
Click on custom.
In the template click on the mustache helper button
and select a suitable field. For example, for a Pingdom tile you might choose:
Copy{{properties.hostname}}
You can also add text to the mustache, or show more properties. For example, you might like to add a dash and then a second property:
Copy{{properties.name}} - {{properties.hostname}}
The sublabel works in exactly the same way. In this example we're going to use a time property. In the sublabel section click custom and then use the mustache helper to find a useful time property. For Pingdom, you might choose:
Copy{{properties.lasttesttime}}
Often this returns the date as a Unix timestamp rather than as a readable time. You can use
timeago
to convert Unix timestamps to show a readable date and time.To change the Unix timestamp to show how long ago it occurred we can use
{{timeago(value)}}
Timeago uses the time value in milliseconds. If your API uses seconds, like Pingdom does, you will need to multiply by 1000,{{timeago(value*1000)}}
for example{{timeago(properties.lasttesttime*1000)}}
Click on done.
