PagerDuty
This dashboard gives an overview of incidents and alerting from PagerDuty.
Resolved (Summary Donut) | Resolved incidents |
Triggered, Acknowledged, Resolved (Scalar) | Insight into the current incidents of each priority |
Incidents Over Time (Line Graph and Sparklines) | Time series showcasing incidents over a time span (customizable and can use page timeframe) |
Recent Alerts (Grid) | List of recent alerts (customizable and can use page timeframe). Also displays which integration alert has been triggered from |
The page timeframe is the timeframe setting a dashboard is currently using. These timeframes are all relative to the current time, for example 7 days ago until now. When a user changes the page timeframe, all tiles that have use page timeframe set will adapt to the new timeframe. (Tiles that do not have use page timeframe set (i.e. are set to specific timeframe or custom timeframe) are not affected and won't change.)
The custom option can be used to set timeframes using ISO 8601 format
Get the latest version of SquaredUp DS Standalone
- Create a Web API provider to connect with your PagerDuty environment.
Use the following settings:TypeSimple authNamePagerDutyNote: The name is case-sensitive and must be entered exactly like given here for the tiles to recognize the provider automatically. If you name it differently, you will need to select the provider manually for each tile on the dashboard.
URLEnter the base url for the PagerDuty API, i.e. https://api.pagerduty.com/default headersEnter your PagerDuty API token in the following format:First box (name):authorizationSecond box (value):Token token=API token from PagerDutyIn SquaredUp DS navigate to the right-hand menu ☰ > system > Integrations
- Under Integrations click Web API.
- Click the authentication type Simple
- In the service name box type in a suitable name, e.g. PagerDuty
- The base URL should be the current PagerDuty API URL, for example:
https://api.PagerDuty.com/ - Under default headers click add
- Add the following information to the boxes as shown below:
Paste into the authorization value box in SquaredUp DS, prepended by
Token token=as shown above. - Click Save.
- In DS Standalone go to the top right hand menu ☰ > Import Dashboard Packs and drag the zip file into the Manual Import box.
