SQL Samples
This dashboard demonstrates how the same base SQL query could be used with each of SquaredUp DS's visualizations. Each SQL visualization slightly modifies how the data from the OperationsManagerDW database is presented to target user requirements. For example, a Status Block to quickly show health or a spark line to show how something has changed over time. The same data source, seven different SQL visualizations!
Get the latest version of SquaredUp DS Standalone
- In DS Standalone go to the top right hand menu ☰ > Import Dashboard Packs and drag the zip file into the Manual Import box.
- Replace the connection string in each of the seven SQL tiles with the connection string to your own OperationsManagerDW database.
- Open the connection panel.
Enter the connection string to your own OperationsManagerDW database, for exampleData Source=fqdn.site.domain.com;Initial Catalog=OperationsManagerDW;Integrated Security=True
Publish the dashboard.
