Dashboard Pack - VM Insights Metrics
This dashboard uses Log Analytics tiles to display key metric data for Virtual Machines, regardless of where the servers are hosted. This dashboard focuses on insights about virtual machines, such as free disk space, CPU performance and security issues.
Create an Azure Log Analytics provider to connect to your Azure instance. Use the following settings:
Name LogAnalytics
For help creating an Azure Log Analytics provider see How to add an Azure Log Analytics provider
