Troubleshooting licensing and activation
Frequently Asked Questions
How do I manage user licenses?
What can I do if users are unable to logon?
How do I know which license is currently being used?
Troubleshooting Activation
How do I activate my license?
Which license key do I use to activate Dashboard Server?
You need a specific Community Edition license activation key to install Dashboard Server Community Edition. This will be a different key to any other you might have received from Dashboard Server for other products. You will have received this by email with your free trial or purchase.
How can I activate if my SquaredUp server cannot connect to the internet?
That's fine, you can perform a manual or offline activation on another computer that has got internet access and then copy the .bin activation file onto the server.
I've been asked to 'reactivate' my license, how do I do that?
You will be asked to reactivate your existing license key, if it has been modified or extended.
If you are adding further SquaredUp servers to a multi-server / high availability environment you should use the Secondary license key for each subsequent server (see Enabling High Availability). The Primary license should only be used for the first server in the deployment.
If you uninstall and reinstall on the same server and you originally carried out an offline activation (as described in How to activate your license offline (manual activation))then you can reuse the same .bin file by browsing to <SquaredUpURL>/InstallLicensehttp://SquaredUpServer/SquaredUpv5/InstallLicense (where SquaredUpServer is the name of the server where Dashboard Server is installed). The .bin file cannot be used on a different server.
An error occurred: The key provided is invalid. Activation keys must consist of at least 5 groups of letters and digits
For example:
The activation key you have entered is incompatible with this version of Dashboard Server
This key has expired
