After installing SquaredUp DS you will be prompted to login and enter a license activation key. You will have been emailed an activation key (often called a license key), which is then activated against a SquaredUp DS installation.
You need a specific DS Standalone license activation key to install SquaredUp DS Standalone. This will be a different key to any other you might have received from SquaredUp DS for other products. You will have received this by email with your free trial or purchase.
Browse to <SquaredUpURL>/activation to get to your server's activation screen.
By default, the URL to your SquaredUp DS instance is: http://SquaredUpServer/SquaredUpInstance
SquaredUpServer is the name of the server where SquaredUp DS is installed.
By default, SquaredUpInstance is SquaredUp. For v5 it is SquaredUpv5. If you gave your SquaredUp DS instance a different application name when you installed it, use the name you chose.
If you deployed SquaredUp DS from the Azure Marketplace:
The URL is https://DNSName of the virtual machine (VM) deployed.
Log in as an administrator on the server.
Click on offline activation. If SquaredUp DS is already activated the link will show as offline reactivation.
Drag the .bin file into the box that says Drop license file or click to install. To return to the screen above browse to <SquaredUpURL>/InstallLicense and log in as an administrator.
Once the file has uploaded click Next and then complete the setup wizard.
If you uninstall and reinstall on the same server you can reuse the same .bin file by browsing to /InstallLicense. The .bin file cannot be used on a different server.
