Azure Virtual Machines Health
This dashboard gives an overview of Virtual Machine Health focused on free disk space, heartbeat and CPU utilization using Kusto Query Language (KQL) to query a workspace in Azure.
Free space | Shows the amount of free space for each disk shown by computer, disk, including a bar chart for the % free disk space as well as the free space in GB and when the data was generated. |
Computer AVG CPU | Shows the computer and the average CPU in a bar chart. |
Agent details | Show the computer and it’s state, the environment it is in, what Operating System it is running, the Azure Resource (if applicable) and when the last heartbeat occurred for that computer. |
Agent details (trend) | Shows the history of heartbeats for the computers in the environment. |
Get the latest version of SquaredUp DS Standalone
- Ensure your virtual machines are collecting metrics in an Azure Log Analytics Workspace.
Create an Azure Log Analytics provider with the following settings:NameLogAnalyticsNote: The name is case-sensitive and must be entered exactly like given here for the tiles to recognize the provider automatically. If you name it differently, you will need to select the provider manually for each tile on the dashboard.
For detailed information see How to add an Azure Log Analytics providerDownload and import this dashboard pack.
- In DS Standalone go to the top right hand menu ☰ > Import Dashboard Packs and drag the zip file into the Manual Import box.
- Enter your Azure workspace in the KQL queries in each tile.
- Open the query panel.
- Enter your Azure workspace in the query.
Publish the dashboard.
