Dashboard Pack - au2mator
This dashboard uses SQL and PowerShell tiles to present performance and health counters for the au2mator- Self Service Portal and a Web API tile to directly open the Self Service Portal in a new tab.
It also contains a quick overview of automation engines, System Center Orchestrator and Azure Automation Runbook Health.
Total Requests (SQL tile - Donut) | Displays the actual state of all requests and their state. Note: This tile uses the page timeframe in its SQL query. |
Heavy Users (PowerShell tile - Donut) | Shows heavy users. Since the au2mator DB only contains the SamAccountName, PowerShell is used to provide the DisplayName from ActiveDirectory. |
Total Services (Scalar) | The number of au2mator Services. |
Top 8 Service Usage (SQL tile - Donut) | The top 8 services by usage. |
Start au2mator (Web API tile) | To start the au2mator – Self Service Portal in a new tab. |
Runbooks Job Status (SQL tile - Donut) | Displays all Runbook Jobs which have the state of failed, warning, or success. Note: This tile doesn't use the page timeframe in its SQL query. |
Running Runbooks (SQL tile - Grid) | A list of all Running and Queued Runbook jobs. Note: This tile doesn't use the page timeframe in its SQL query. |
Azure Automation (Azure Log Analytics tile - Donut) | Displays the Azure Automation Runbook Jobs state. Note: This tile doesn't use the page timeframe in its SQL query. |
Create an Azure Log Analytics provider with the following settings:
Name squaredup
For detailed information see How to add an Azure Log Analytics provider
Replace the connection string in the SQL tiles (Total Requests, Total Services, Top 8 Service Usage, Runbook Job Status, Running Runbooks) with the connection string to your own au2mator database.
Open the connection panel.
Enter the connection string to your own au2mator database.
Edit the script in the Heavy Users PowerShell tile to query data from your au2mator database.
Edit the tile by clicking the Edit button.
Open the script panel.
Insert your au2mator database.
Edit the Start au2mator Web API tile to connect to your au2mator Self Service Portal.
Open the content panel.
Insert the URL to your au2mator Self Service Portal.
Publish the dashboard.
How to publish a dashboard
