Salesforce
This is a really simple dashboard showing how to use the Salesforce API to query for data using SOQL (Salesforce Object Query Language). It displays summed up accounts, contacts and opportunities using the SOQL count function.
Get the latest version of SquaredUp DS Standalone
- A Salesforce Admin needs to create a new Connected App in Salesforce with the following settings:
- "Enable OAuth Settings" - activated
- A callback URL in the format
https://your-squaredup-server-url/SquaredUp/ext-core-webapi/callback/Salesforce
Note: The last part of the URL has to be Salesforce, because it needs to be identical with the name of the provider you're going to create for the tiles in this dashboard. - Granted OAuth scopes:
Manage user data via APIs (api)Perform requests at any time (refresh_token, offline_access)
- IP restrictions:
Change theIP Relaxationsetting toRelax IP restrictionsin theEdit Policiesarea.
Alternatively, you can whitelist the IP address for your SquaredUp server in theProfiles adminarea.
- Create a Web API provider to connect to your Salesforce environment with the following settings: TypeOAuthNameSalesforce
Grant typeAuthorization codeBase URLThe base URL to your Salesforce environment in the formathttps://your-salesforce-org.my.salesforce.com/services/data/v52.0/Ignore invalid SSLOffSend authorization with queryOffAuthorization URLhttps://login.salesforce.com/services/oauth2/authorizeToken URLhttps://login.salesforce.com/services/oauth2/tokenClient ID and secretTheConsumer Keyof the Connected App you're using for SquaredUp DS. You can find it in Salesforce, in the App Manager area of the Connected App.Note: When creating a new Connected App in Salesforce, it can take 20-30 minutes before the Consumer Key becomes active for API usage. This may cause the provider to fail to authorize. If this happens, wait 10 minutes and then click Perform Authorization again.Client secretTheConsumer Secretof your Connected App you're using for SquaredUp DS. You can find it in Salesforce, in the App Manager area of the Connected App.Authorization scopeapi offline_accessIn SquaredUp DS navigate to the right-hand menu ☰ > system > Integrations
- Under Integrations click on Web API and choose either Simple, Basic Auth or OAuth depending on the API you are using.
Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.SimpleNo authentication, basic authentication (username and password in a header) or Windows authentication (configured automatically to use the application pool identity account).
Basic authBasic authentication. Your specified username and password will be Base64 encoded automatically.
OAuthToken-based authentication according to the OAuth 2.0 standard. Many APIs use OAuth 2.0 for authorization, and will require an OAuth provider to include the additional information about how to authorize against the service.
- Complete the provider fields, using your API provider's online documentation as a guide.
- You are now ready to use this provider in a Web API tile (see How to use the Web API tile).
- In DS Standalone go to the top right hand menu ☰ > Import Dashboard Packs and drag the zip file into the Manual Import box.
- Each tile has a Salesforce SOQL query in the Headers & Data panel. Change the query to a query that works for your Salesforce environment:
- Open the Headers & Data panel.
- Paste your query in the Data section.
Examples for generic queries you can use:SELECT Name FROM AccountSELECT Name, Owner.Name FROM AccountSELECT Count(Name) FROM Contacts
Publish the dashboard.
