Symptoms
When activating Dashboard Server you see:
or
Procedure
If you are adding further SquaredUp servers to a multi-server / high availability environment you should use the Secondary license key for each subsequent server (see Enabling High Availability). The Primary license should only be used for the first server in the deployment.
If you uninstall and reinstall on the same server and you originally carried out an offline activation (as described in How to activate your license offline (manual activation))then you can reuse the same .bin file by browsing to <SquaredUpURL>/InstallLicensehttp://SquaredUpServer/SquaredUpv5/InstallLicense (where SquaredUpServer is the name of the server where Dashboard Server is installed). The .bin file cannot be used on a different server.
