SQL provider
What are Integrations?
What is a provider?
  • generic Web API providers that can connect to any REST API
  • dedicated providers that connect to a specific external platform or database (SQL, ServiceNow, Azure Active App Insights, Elasticsearch, etc.)
About SQL providers
An SQL provider contains the connection string to the SQL database you want to connect to. You can use Microsoft SQL Server or ODBC drivers for your connection.
Since SquaredUp DS version 5.4 you need an SQL provider to use the SQL tile. . If you haven't created an SQL provider yet, you need to create a provider first.
If you created SQL tiles before SquaredUp DS version 5.4, they were created with a connection string in the tile instead of a provider.
Adding an SQL provider
  1. Make sure you have access to the database you want to use.
  2. Provider name:
  3. Driver and Connection String:
  4. Click save to save your new provider.
To use the SQL provider in a tile see How to use the SQL tile
