How to add a Pingdom provider
Before you configure the Web API tile for use with Pingdom you need to create a Pingdom provider in Dashboard Server.
You may like to refer to the Pingdom API documentation or speak to your Pingdom expert.
For Pingdom the provider must be created as a simple provider:
Add the following:
value:Bearer
<API token from Pingdom>
Bearer
and a spaceClick Save.
