How to add an SQL provider
What are Integrations?
What is a provider?
About SQL providers
Since SquaredUp DS version 5.4 you need an SQL provider to use the SQL tile. .
If you created SQL tiles before SquaredUp DS version 5.4, they were created with a connection string in the tile instead of a provider.
Adding an SQL provider
Make sure you have access to the database you want to use.
Configuring access to a database for an SQL provider
To be able to query databases, such as the Operations Manager database, the SquaredUp DS application pool identity needs to be given the db_datareader role in SQL Server Management Studio for the database you wish to query. See How to configure access to a database for use with the SQL tile.
Provider name:
Driver and Connection String:
Connection strings when you are using Microsoft SQL Server Driver
Connection string for any database:
With integrated security:
CopyServer=<SQLservername>;Database=<DatabaseName>;Integrated Security=True;
With username and password:
CopyServer=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
CopyServer=<SQLservername>\\<InstanceName>;Database=<DatabaseName>;Integrated Security=True;
Example:
CopyServer=SQLServer1\\Main;Database=CRMDB;Integrated Security=True;
If you want to specify a port
CopyServer=<SQLservername>,<PortNumber>;Database=<DatabaseName>;Integrated Security=True;
Example:
CopyServer=SQLServer1,51433;Database=CRMDB;Integrated Security=True;
Connection strings when you are using ODBC
Note: You need to use 64-bit ODBC drivers.
Example:
CopyDriver=<ODBCdriverName>;Server=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
If you are using a System DSN
CopyDSN=<DSNname>
Click save to save your new provider.
To use the SQL provider in a tile see How to use the SQL tile
