How to add a PagerDuty provider
Before you configure the Web AP tile for use with PagerDuty you need to create a PagerDuty provider in Dashboard Server.
For PagerDuty the provider must be created as a simple provider:
https://api.PagerDuty.com/
Under default headers click add
First box (name):
authorization
Second box (value):Token token=API token from PagerDuty
Copy the API access key from PagerDuty before closing the window:Paste into the authorization value box in Dashboard Server, prepended by
Token token=
as shown above.Click Save.
