How to use the ServiceNow tile
About ServiceNow tiles
The ServiceNow tile allows you to query incidents and change requests from ServiceNow and display this data in Dashboard Server.
Dashboard Server Community Edition Enterprise edition (or above) is required for access to the Splunk tile, ServiceNow tile, Azure App Insights tiles, High Availability, and Team Folders.
For more information about license pricing see pricing information.
To upgrade please contact sales@squaredup.com
To check the license edition you are using see How to check which license key is being used.
The ServiceNow tile offers easier configuration than the Web API tile. You can display incidents and change request with the ServiceNow tile. If you want to use any other data from ServiceNow, you need to use the Web API tile.
For more information about using the Web API tile with ServiceNow see How to use the Web API tile with ServiceNow.
How to configure a ServiceNow tile
If you don't already have a ServiceNow provider, you need to create one before you can configure a ServiceNow tile (How to add a ServiceNow provider).
Add a new tile to a dashboard or a perspective and choose the ServiceNow tile.
Select the visualization for your ServiceNow tile:
Donut
Shows the results in a donut shape.
Example:
Scalar
A single value such as a number of customers or incidents.
Example:
Grid
Provider:
Select your ServiceNow provider from the select provider drop-down and click next.
You can only use providers of the same type as the tile. Providers of other types won't be shown in the select provider drop-down.
Note: If you click on add new, you can create a new ServiceNow provider in a new tab. Click on reload after you created the new provider to be able to choose it from the drop-down.
Table:
Table:
Here you can choose if you want to get incidents or change requests (for any other data, you can't use the ServiceNow tile and need to use the Web API tiles, see How to use the Web API tile with ServiceNow).
View:
Here you choose the view that determines the set of columns which will be displayed. Views are created in ServiceNow and the list of views is populated from there.
If you only see the non-admin default view in the View dropdown
It depends on the ServiceNow account you are using for a provider if you can see all the available views or only the non-admin default view in the View dropdown.
The permissions of the ServiceNow account you are using for your ServiceNow provider affect what you can see and do in the ServiceNow tile.We recommend using a service account, which means you create an account specifically to use with the ServiceNow provider. You have different options for setting up this service account:
ServiceNow admin account
Give the ServiceNow account the admin role. This will give you full functionality in the ServiceNow tile.
ServiceNow non-admin account with ACLs
If you don't want to use the admin role due to security concerns, give the ServiceNow account only the rest_api_explorer role and use ACLs to give the account more rights. This will limit the functionality of the ServiceNow tile a little bit (see table below).
How to add the necessary ACLs to your ServiceNow account
When you are using a non-admin ServiceNow account for a provider, the functionality of the ServiceNow tile is limited:
You'll see an error when you used a scope for your tile
Adding them directly to a user account, meaning you are adding the ACLs to the service account you are using for the ServiceNow provider.
Adding them to a role. We recommend that you create a new role specifically just for adding the ACLs to it. Then you need to assign the role to the service account you are using for the ServiceNow provider.
A benefit of adding the ACLs to a role is that it makes them easier to manage and you can assign the role to different users (in this case, service accounts) if you want to use different service accounts for different ServiceNow providers.
sys_filter
sys_dictionary.*
sys_dictionary
sys_db_object
sys_ui_list
sys_db_object.*
sys_ui_list.*
The tile can be scoped
If you don't want to create ACLs and use only roles, give the ServiceNow account the roles rest_api_explorer and web_service_admin. This will limit the functionality of the ServiceNow tile a little bit (see table below).
yes (due to the ACLs) yes (due to the web_service_admin role) Being able to see all views in the View dropdown, not only the default view yes no no Being able to see all default filters, not only user-made ones yes yes (due to the ACLs) no Filter:
Here you choose a filter to restrict the query to certain items. You'll see default filters from ServiceNow and filters that have been created by users in ServiceNow.
If you only see user-created filters but no default filters
It depends on the ServiceNow account you are using for a provider if you can see the default filters.
sys_filter
sys_dictionary.*
sys_dictionary
sys_db_object
sys_ui_list
sys_db_object.*
sys_ui_list.*
yes (due to the ACLs) yes (due to the web_service_admin role) Being able to see all views in the View dropdown, not only the default view yes no no Being able to see all default filters, not only user-made ones yes yes (due to the ACLs) no Configure the settings for the visualization you chose:
Settings for Scalars
Scalar
Color
Conditional formatting:
value
property and manipulate it with JavaScript String and Regex APIs. When you click on the mustache picker, you'll get some examples:Value is greater than something, less than something, etc.
For example:
{{value < 10}}
(The color you picked will be used if the value is less than 10)Value is present in the result
For example:
value.IndexOf('error') != -1
(The color you picked will be used if the string value "error" is present in the results)Value matches one of the regular expressions you defined
For example:
value.match(/healthy|good|up/)
(The color you picked will be used if the string values arehealthy
,good
, orup
Display:
, where123
.For scalars, you can only use the dynamic property
value
in dynamic links, which means the link changes when the value of the scalar changes. Since a scalar is just one item, it would also make sense to use a fixed link, for example the link to the website of which you are displaying the response time.For status icon or bars and the rows of a grid, you usually want to use a dynamic link since you get multiple items or rows that represent different things. You can use any of the dynamic properties the mustache picker offers you.
Examples for URLs with dynamic properties for popular APIs
Dynamic mustache properties and values you need to change according to your instance are highlighted in bold.
ServiceNow incidents:
PagerDuty incidents:
{{incident.html_url}}
Azure DevOps projects:
Azure DevOps builds:
Zendesk tickets:
Azure Application Insights
Settings for Donuts
Display
Size mode:
Display mode:
Settings for Grids
Display
Limit:
Allows you to change the limit for the number of rows of data returned (default is 20).
Sort by:
Allows you to sort the data by a column in ascending or descending order. The Sort option uses the many incident fields, and you can sort by one of them even if that field is not currently displayed in your results table. To make this more clear you may like to reference this in the tile title, for example
Incidents, sorted by priority
.Click done to save the tile.
FAQs
Why can't I find the provider I created in the dropdown list?
If you are unable to see your provider in the list check that it is a servicenow provider. Any other types of providers will not be shown in the dropdown.
How do I query data other than Incidents or Change Requests ?
The ServiceNow tile can only show Incidents or Change Requests. If you wish to query other tables use the Web API tile to query the ServiceNow API instead of the ServiceNow tile (see How to use the Web API tile with ServiceNow).
How do I create a new view or filter ?
The list of views and filters is pulled from ServiceNow. When you create any new views and filters in ServiceNow they will be available in Dashboard Server.
